suspension issues
Old Jan 15, 2008 | 09:04 PM
caddyking19's Avatar
Default suspension issues
i have a 92 vic with stock air bags..i want to lift it a little bit to put 22s but i cant find a site that sells a lift for bags just springs..could i take the bags out an put spprings in or is there a lift out there for vics with bags! help!!!
Old Jan 15, 2008 | 09:10 PM
87_Crown_Vic's Avatar
Default RE: suspension issues
you would have to take out the pump under the hood, remove ol air lines, install springs for it and also new shocks all the way around. you can get the type of air shocks that can be adjusted manually at a decent price.
Old Jan 15, 2008 | 09:18 PM
i can get those airchocks an they will work with air bags.. i just need like 3 inches more lift to clear these 22s..this website makes spacers that go under the coils could i put thse under the bagss
Old Jan 15, 2008 | 09:45 PM
i would suggest cargo springs in the rear with a manual adjust air shocks... manual adjust air shocks in front will give more clearance also. how thick are your sidewalls?
Old Jan 16, 2008 | 12:56 PM
oldtimer35's Avatar
In answer to your question about using the spacers with the air bags, no. The air bags lock into the seat on the pad part of the diff housing. Without that seat, they will come out, under pressure, and that ain't no fun.
Old Jan 16, 2008 | 05:22 PM
haha thanks for that info i dont want to be dragging my bumper...can i switch the bags out with springs tho??? or do i need to change the axle
Slednchick
Dec 22, 2012 04:29 PM
bugman114
Jun 21, 2012 10:44 PM
Adolfo Dougy Sanchez
Jun 4, 2012 11:37 PM
rog64ert
Oct 21, 2011 03:47 PM
redrover
Feb 26, 2009 11:07 AM
