vic problem areas
Old Nov 3, 2008 | 11:36 PM
cutiepiereading's Avatar
Default vic problem areas
I have a 97 vic that is in pretty good condition and I would like to keep it until "the wheels fall off", what are the typical problem areas on the vics and are there any steps to pre-empt the problems? So far I've learned that the Coolant temperature sensor can cause problems when dirty and the Multi function switches have issues. If possible I would like to use an ounce of prevention over a pound of cure.
Old Nov 10, 2008 | 03:20 PM
oldtimer35's Avatar
Default RE: vic problem areas
just keep reading the posts
Old Nov 17, 2008 | 07:41 PM
94crownvicon22s's Avatar
I was told that between 130,000 and 150,000 miles if you dont flush the radiator and cooling system, that the old antifreeze can eat the head gaskets. I didnt believe him at first until it happened to me. So I stronglysuggest you doing that. the head gaskets are a humdinger to change.And the cooloing system sucks om the 4.6 anyways. and the odometerbreaks but not a big deal.
gpk9
Dec 17, 2015 03:35 PM
May 2, 2012 10:36 AM
VicOnVogues
Nov 17, 2008 07:46 PM
Aug 9, 2005 03:22 PM
