1995 ford shuttle bus runs poorly after 30 minutes
Old Apr 18, 2012 | 12:17 AM
markcass123's Avatar
Default 1995 ford shuttle bus runs poorly after 30 minutes
Hey guys,
I got a 1995 ford shuttle bus with a 7.5 L gasoline engine. It says e350 on the registration.... were converting it to a tailgating bus... I've done a basic tune up on the bus... air filter, fuel filter, oil change, spark plugs and wire. It runs better no ticks anymore and feels more powerful... I recently took it out on a long drive and it drove great for about 30 minutes. I felt a funny rumble inside the car and then all of a sudden it had very poor acceleration. Even if you pumped the gas it wouldnt want to go anywhere. Then I pulled over on the side of the rode stopped for about a min or so... started the car up and had power again. I began to head home it drove fine for about 10 mins and the same thing happened. I pulled over let it sit and started it up again and had power again. Any idea what this is? Where should i start troubleshooting?
Old Apr 18, 2012 | 11:03 AM
As a first step, I'd put a fuel pressure gauge on the fuel rail and monitor the pressure/volume when it starts to stall out to be sure its not a fuel delivery problem..
Old Apr 18, 2012 | 12:11 PM
is there a fuel pressure test spot on the fuel rail of this vehicle ?
Old Apr 18, 2012 | 12:12 PM
what should i look for the pressure to be at?
Old Apr 18, 2012 | 12:57 PM
There's a schrader valve on the right/passenger side forward of the fuel rail.. Pressure should be about 35/45 with just the key cycled ON, or if running about 30/45ish..
When it started to stall, would it still idle fine? Did it misfire?
Old Apr 18, 2012 | 01:07 PM
It would have no power, the idle sounded rough and i could hear a thump from the engine bay(under my feet) if i would pedal the gas. I just pulled off the road parked it turned it off let it sit for a few mutes and restarted it the engine was now running fine again and had torque. Any ideas?
fordborn
Sep 5, 2011 01:33 PM
tahafisaka6
Feb 14, 2011 10:59 PM
biz505
Jul 23, 2007 10:18 AM
Shaylaina
Nov 2, 2006 11:26 AM
amexjoe
Feb 3, 2006 09:11 PM
