2000 E-350 V10 A/C Compressor wont run
Old May 7, 2008 | 09:07 PM
sgariety's Avatar
Default 2000 E-350 V10 A/C Compressor wont run
Before I jump to any conclusions and replace the clutch any additional suggestions?
She only has 65K miles...
Thanks!!
Old May 7, 2008 | 10:59 PM
Default RE: 2000 E-350 V10 A/C Compressor wont run
Is there 12v out at the compressor clutch? Check the low pressure/cycling switch on the drier for 12v in/out with the connectorstill pluggeg in, and A/C mode selection to on.. If there's 12V 'in' on one leg only, unplug the connector and bridge the connector pin socketsand see if the compressor spins.. There should be 12v at the drier switchconnector with the A/C function on...
Here's a generic pic fo clarity..
[IMG]local://upfiles/6756/BE273C4F70CA47C2AAFF581F18805EE9.gif[/IMG]
Old May 29, 2008 | 09:36 PM
sgariety's Avatar
Ok, we have finally gotten back to this problem...now my car(98 crn vic) wont start, so 2/3 of my vehicles have failed me....our 84 E-150 panel van with 145k on it runs AND has A/C!!!
Anyway....we have taken the connector off of the A/C coil/clutch and there is no power coming into the clutch/coil. Is there a relay or fuse we are missing? Thanks a ton, again!
bosanci28
Apr 17, 2010 11:33 PM
soldiernchrissy
Jan 25, 2008 07:24 AM
rispeed
Oct 29, 2005 06:09 PM
highpowerd2003
Sep 18, 2005 11:27 AM
highpowerd2003
Sep 8, 2005 11:46 PM
