2003 E-150 Rear Axle Leak
Old Jan 6, 2019 | 03:15 PM
ABLE1's Avatar
Default 2003 E-150 Rear Axle Leak
Hello,
I have a 2003 E-150 with 193k miles. Just found out that the rear axle on the right side is leaking oil
due to a rusted area at the U-Bolt clamp location.
Any thoughts on the seriousness of this??
Is there a known acceptable repairs that can happen??
Thanks,
Les
Old Jan 6, 2019 | 09:10 PM
Welcome to the site..
Id inspect the area affected, but should be able to put a patch over the rusted area..
Old Jan 6, 2019 | 09:17 PM
ABLE1's Avatar
Thanks for the response!!
What kind of patch were you thinking??
Something welded around the affected area or something different??
Thanks,
Les
Old Jan 6, 2019 | 10:53 PM
Would depend on where, and how much.
It’s rusted through under the u bolts contact points only?
If a rust through area under the u bolt caps/bends, guessing it is, not a crack, a patch could be fabbed and welded on. Trying to weld over/around rusted, oily areas can go from bad to worse very quick. Any chemical or cold patch would be a band-aid..
Old Jan 7, 2019 | 06:28 AM
ABLE1's Avatar
It is a 3" section at the U-Bolt closest to the center of the van. It appears to be a heavier section
of the tube that helps to support the rear end. The heavy portion has rusted away. The inner tube
is still there after I chipped away the rusted 1/4" layer??
As I see it the tube would need to be cleaned up quite a bit in order to apply anything like maybe
PC-7 Epoxy or something else that might be suggested. Any thoughts on what to use??
Thanks,
Les
Old Jan 7, 2019 | 10:05 AM
Can you post a few images?
Old Jan 7, 2019 | 06:21 PM
ABLE1's Avatar
I will try to get some pictures but the weather is not being cooperative lately,
However, today I noticed a larger oil splotch on my driveway.
So I contacted my local shop and gave a green light to pick up a replacement rear end.
Hopefully all will go well.
Les
Skoalbandit33
Mar 23, 2019 06:23 PM
sook120
Jan 4, 2017 01:06 PM
nct53
Nov 8, 2011 03:35 AM
bluewind
Sep 6, 2011 03:09 PM
ford1940
Mar 28, 2010 04:21 PM
