2006 e250 no brake lights. Everything else works
Old Apr 11, 2022 | 10:50 AM
Skian's Avatar
Default 2006 e250 no brake lights. Everything else works
How do you check the multifunction switch??
Ok, non mechanic fumbling here. Here is where I sit.
checked bulbs, good but replaced
checked #11 15 amp fuse good but replaced
checked brake light switch good but replaced
the back is built out and I’m trying to troubleshoot without pulling the shelving. 😂
I’m on to the multi function switch now. I don’t know the color of the wire coming into it to see if I have power going in, and I don’t know what wire to check going out as I don’t have a diagram.
im tempted to just buy a multifunction switch at 150 bucks, but that ain’t like a 6 dollar bulb.
Can somebody tell me how to test the multifunction switch in place before I spend 150 to replace it?
Old Apr 12, 2022 | 04:47 AM
raski's Avatar
My bet is on a bad wiring for the brake lights. Sockets and exterior wiring is where I would look first.Start from the rear and work your way up front. I doubt your multifunction switch is bad and don't see the relationship with the brake lights.Are your turn signals and park lights working in the rear?
jaxvet
May 31, 2014 12:30 PM
BBQJOE
Oct 3, 2013 05:52 AM
chadl73
Sep 28, 2012 09:05 AM
greenpeace
Sep 9, 2009 11:08 PM
dean99
Dec 23, 2008 11:23 AM
