2006 E350 superduty van transmission leak
Old Nov 3, 2021 | 01:48 PM
Brandonabandon's Avatar
Default 2006 E350 superduty van transmission leak
Hi. New to the forum and not very mechanically inclined, but I thought it possible I may be able to fix my vans issue with some advice. My van is not holding transmission fluid whatsoever and leaking from a wobbly bolt when I add it. I will add some pics. I need advice on the name of that bolt/ area that needs repaired, if itself is the actual problem. I should add that bolt is free spinning as if the top of the bolt isn't actually connected to the shaft of the bolt, making it impossible to loosen/tighten.
I appreciate any and all advice as attempt to fix this issue. Thanks again.
Old Nov 7, 2021 | 01:59 PM
That's the trans case vent. The cap is supposed to be loose.
How many miles on the trans, and OD/Tow Haul lamp flashing?
Old Nov 7, 2021 | 02:11 PM
I was told the transmission was new from 1-2 years. Bought the van roughly 4-5 months ago. The vehicle has 250+ miles. The transmission light is on and the od light will come on/flash if I try to drive
Old Nov 12, 2021 | 05:51 AM
raski's Avatar
An overfilled transmission will send fluid out the vent.
Hasaford
Jul 28, 2020 09:28 PM
b-love508
Mar 18, 2018 02:39 PM
jdshivers0613
Dec 10, 2016 09:42 AM
B350
Mar 16, 2016 05:36 PM
iuecbrad
Nov 15, 2012 05:57 PM
