2011 E150 Radio Removal
Old Oct 31, 2011 | 01:16 PM
DanDanTechnoMan's Avatar
Default 2011 E150 Radio Removal
How do you remove the stock radio in the 2011 e150 van? It has no holes in the face of the radio but looks like it is mounted into the main dash bezzel not behind it
Old Jun 2, 2014 | 10:59 PM
tom hartzell's Avatar
i have a 1991 ford econoline with a 5.0 engine, the fuel pump quit so i replaced the fuel pump relay under the hood still nothing. is there a fuse for this too? checked all those too, there are 3 metal ones two short an one long do these have anything to do with it? it will run if i put power to the positive side of the pump--- can someone help
Old Jun 3, 2014 | 11:35 PM
Nothing at the inertia switch?
Old Jun 9, 2014 | 09:07 PM
i have bypassed the switch an i have the pump running when the key is on, the problem is that after it sets over night it doesn,t want to start, i have done a pressure test an have 40 lbs of fuel pressure with the engine off 50 lbs when it,s running, could it be the fuel filrer getting plugged up? is there anouther sencer out? what could it be ? i am running out of ideas can someone help?.
Old Jun 10, 2014 | 04:36 PM
after much hunting an head scratching i found the problem there is a water temp sensor in the intake, not the one for the guage but it,s in the middle of the intake with two wires that plug into it if it,s bad it won,t let it start.
silentlooker
May 14, 2012 01:46 AM
cardiag12
May 16, 2011 03:01 PM
bread320i
Mar 17, 2007 03:01 AM
todder
Oct 23, 2006 02:36 AM
