5.4 Liter Coil And Plug Changes 1999 E150 Econoline
Me and my Dad are in the process of replacing all plugs in my 5.4. We have put new coils in 6 and 8 cylinder. Putting old coil back on the others. Pulled out coil in cylinder 3 with no problem but it doesn’t reinstall easily. It seems too large but it is the same size as the other coils. Came out easily but having to stuff it back in. Anyone have experience with this?
Last edited by CorissaMarie333; May 26, 2024 at 09:41 AM. Reason: 1999 Ford E-150 5.4 V8 Van
When you say it "seems too large", do you mean the boot is too big to go into the engine or that the head of the coil is too big to fit around obstacles?
Make sure there are no obstructions in the plug well and try the coil from a different cylinder in that location.
[QUOTE=dpboone;141971]You cannot just disable componemts and cut wires. EVERTHING routes through the ECM and sometimes there are crossovers between systems that will cause issues like you have reported.[/QUOTE
Sure, that’s what’s happening now. I understand it wasn’t ideal to do that now and I’m interested in any advice on bypassing this. Thanks
