-   Ford Econoline E Series (https://www.fordforum.com/forum/ford-econoline-e-series-18/)
-   -   92 Conversion Van Build (https://www.fordforum.com/forum/ford-econoline-e-series-18/92-conversion-van-build-28574/)
Dancing4raiin Nov 19, 2012 03:20 PM
Hello All,
I bought a 92 conversion van a few weeks ago off of Craigslist and wanted to start a thread to document it, and also get help with the mechanics of it. I paid $850 for the van that runs, but the check engine light is on. I'll be posting some pictures shortly. I bought a scanner and it is giving me error code 332, but cant find the leak.
Dancing4raiin Nov 19, 2012 03:51 PM
4 Attachment(s)
The van is not in the best condition since the interior smelled HORRIBLE, and all the seats are falling apart.
Attachment 2368
Attachment 2369
Attachment 2370
Attachment 2371
Dancing4raiin Nov 19, 2012 03:53 PM
4 Attachment(s)
Attachment 2364
Attachment 2365
Attachment 2366
Attachment 2367
http://i725.photobucket.com/albums/w...n/Van/van9.jpg
Dancing4raiin Nov 19, 2012 03:55 PM
5 Attachment(s)
Attachment 2359
Attachment 2360
Attachment 2361
Attachment 2362
Attachment 2363
Dancing4raiin Nov 19, 2012 03:57 PM
1 Attachment(s)
I paid $120 for them to shampoo the interior of the van because i did not want to touch it. If i get the engine to work i will be tearing the interior out.
Attachment 2358
Dancing4raiin Nov 19, 2012 05:24 PM
I'm mainly doing this so people could give me feedback on engine questions so PLEASE feel free to ask me any questions, offer suggestions, or just participate to help me out and motivate me to continue updating!
hanky Nov 19, 2012 05:38 PM
Welcome and good luck with your new hobby.
Motivation,,??? I think you're gonna need some ! (Just kidding)
You can start with what engine is in the van, mileage, what if any service was known to have been done. Feel free to supply as much info as you can and will try to answer as many questions as we can. You may have some problems getting parts , but there are many places where you can get most anything. It doesn't appear to have dual tanks And that could be good. Good job with the pix.
Dancing4raiin Nov 19, 2012 06:35 PM
1 Attachment(s)
Hanky thanks for getting back. As far as service i knew they did an alternator rebuild and put in a new battery. The van has 167K miles and the vin says it should be a 5.0V8 but when i routed the spark plug wires i had to do the 5.8V8 sequence or it would not start (found it online). I changed out the spark plugs and now the engine sounds like it is going to die out when it first starts. I cleaned the EGR valve, and am still getting the 332 code. I also realized some of the spark plugs have unburnt gasoline on them.
Attachment 2357
hanky Nov 20, 2012 02:44 PM
That 332 code says no EGR operation detected which could mean the sensor on the EGR valve is in need of replacement or there may be no vacuum to the EGR valve for it to operate Or the valve itself may be defective Or possibly a wiring problem at the sensor.
Most of the time the sensor on the valve went south and just needed to be replaced.
You might want to be extra careful when removing the 3 sensor hold down bolts they get pretty rusty and if not soaked with penetrating oil can snap off pretty easily. If you decide it's the sensor make sure you also replace the red "o" ring under the sensor too.
Dancing4raiin Nov 20, 2012 05:11 PM
1 Attachment(s)
Hanky thanks for getting back to me and helping me out with my thread. I will look into the EGR valve since that was one of the first things I looked into. The more puzzling and frustrating problem i've ran across now is an idling issue. I tried changing out the spark plugs and all of a sudden its misfiring, and choking out the engine. I've tried checking the firing order and everything i've tried still ends up the same. There is also lots of unburnt gasoline now that makes the whole air smell heavily of gasoline, and some of the plugs have unburnt gas on them. My friend came over and also said that the 6 and 8 piston or cylinder were not firing properly because the engine did not stall out when the spark plug wire was removed. I really need some help to find out what i did wrong, or what exactly am i looking at in regards to repairs! PLEASE HELP! if you know of any other threads i could read i would appreciate it.
Could it be possible that there is something with the distributor cap, or would it be something more serious in the engine? The reason i dont understand is why it did it after i changed the spark plugs. I made sure i had the correct gaping and everything.
Does anything inside the distributor look bad?
Attachment 2356
