97 e150 rough shaky and loud
I have 114 k on my 97 e150 6 cyl. Always got 15 mpg, not much power. Yesterday it started shaking and making pinging noises. Nothing obvious visually. Heard it might be transmission or dropped piston. Anything else it might be? Would love any advice or direction before I send it off to a mechanic that I don't know. Would like to troubleshoot it before I send it to em. Great van. Want to keep it going. Any ideas where to start? Thanks. Jef
Just oil/filter changes. It has only gotten 15 mpg since I bought it, supposed to get 20, alwys had low power, and cruise never worked smooth enough to work. I heard from the original owner that it sat and got water in the fuel but Ive ran it 17k since then. I put plugs/wires in it about 7 k ago. It shifts and drives but I'm worried it will seize. Its a metal/ metal sound. gets worse with acceleration and calms down at idle. towards the rear of the block. Gonna pull the plugs and see what they look like before I do anything else. Lost right now. Anything ideas are helpful, thank you.
Yes! It is entirely possible the substrate in the catalytic converter is in pieces and is providing an obstruction in the exhaust system. This could certainly explain the loss of power and the noise. If I remember correctly , those converters were an assembly with two pipes from the exhaust manifold and were very expensive. Nothing compared to major engine work and the bonus, after the repair, is increased MPG and more power.
