AC service port
Old Jun 15, 2007 | 05:48 AM
neddley's Avatar
Old Jul 5, 2007 | 11:11 AM
bamlin54's Avatar
Default RE: AC service port
This may help. Had the same problem on my 90 E250, 460 V8. Finally spoke with a mechanic that knew what he was doing. On my vehicle, I had to remove the entire air cleaner assembly to get access. It was not that hard to do. Once removed I still could not see the low side schrader valve but the suction line runs under the windshield cowl across the vehicle and when you run your hand along the suction line you will feel the valve. It is located under the center of the windshield. Hope this helps.
Old Jul 20, 2011 | 01:28 AM
jgfan24's Avatar
Default low pressure port for 1986 Ford Econoline 150
Thank you Bamlin54 for helping me locate the low pressure port. I spent two days trying to find it.
Thank you again.
thalchak
Mar 20, 2013 11:42 AM
tacamo
Dec 14, 2008 02:15 PM
iplaypearldrums
Jan 1, 2008 05:44 PM
bigjake
Aug 25, 2007 07:16 PM
gearyoil
Nov 1, 2005 07:02 PM
