E250 distributor I6 4.9L
Old Feb 10, 2007 | 09:49 PM
trex66's Avatar
Default E250 distributor I6 4.9L
I replaced my distributor, marked the spot on the distributor, but forgot to mark the rotor. Does anyone know the procedure so I can get the timing back?
Old Feb 10, 2007 | 10:00 PM
Default RE: E250 distributor I6 4.9L
Put the crank/timing mark on TDC (compression stroke), then drop the distributor in with the rotor pointing at #1.. If you get it off/out by 180 degree's (exhaust stroke) thenlift the distributor out far enough to turn the rotor/shaft and drop it back in 180 in the opposite direction...
Old Feb 10, 2007 | 10:07 PM
trex66's Avatar
thanks haya
fordmann67
Dec 21, 2005 04:02 PM
cwbronc
Jul 12, 2005 07:17 PM
blue_streak
Apr 8, 2005 03:24 PM
jrocco
Jan 28, 2005 04:08 PM
jfhattsr
Oct 21, 2004 05:46 PM
