E350 speedometer acts
1996 E350 based 21 feet Class C with a 460 ( 7,5L )....
the speedometer fluctuates around 60 mph & over ......the cruise control wont hold because of this ... ABS light on also ! Id like to know what is causing this : I know the oïl is new in the diff and the abs ring teeth are good , connector ok too.( tried another one also same results ) I heard about cluster .... is it normaly the most obvious reason ? any hints ? thanks Dan |
The fact that the ABS light is illuminated means there should be a code in the computer to provide some guidance as to where the problem is originating.
athnks Hanky,
the 96 does not have OBDII .......how can I get the codes? thanks Dan |
The codes are still available, some code readers will read OBD I .
There is another way and that requires a voltmeter and using the diagnostic plug and following a specific procedure. With the second method you count the blinks of the check engine light and refer to a code listing to get the description of the code. The procedure is probably available over the internet .It is much better to watch a video than to try to understand the writings of someone trying to explain it. |
thanks hanky
ill check because I dont think i have a check engine light on |
You would then watch the deflection of the needle on an Analog voltmeter and count the times the needle rises and falls.
