E350 speedometer acts
Old Jul 27, 2018 | 01:14 PM
BigDan's Avatar
Default E350 speedometer acts
1996 E350 based 21 feet Class C with a 460 ( 7,5L )....
the speedometer fluctuates around 60 mph & over ......the cruise control wont hold because of this ... ABS light on also !
Id like to know what is causing this :
I know the oïl is new in the diff and the abs ring teeth are good , connector ok too.( tried another one also same results )
I heard about cluster ....
is it normaly the most obvious reason ? any hints ?
thanks
Dan
Old Jul 27, 2018 | 01:17 PM
The fact that the ABS light is illuminated means there should be a code in the computer to provide some guidance as to where the problem is originating.
Old Jul 27, 2018 | 01:26 PM
BigDan's Avatar
Unhappy
athnks Hanky,
the 96 does not have OBDII .......how can I get the codes?
thanks
Dan
Old Jul 27, 2018 | 02:51 PM
The codes are still available, some code readers will read OBD I .
There is another way and that requires a voltmeter and using the diagnostic plug and following a specific procedure. With the second method you count the blinks of the check engine light and refer to a code listing to get the description of the code. The procedure is probably available over the internet .It is much better to watch a video than to try to understand the writings of someone trying to explain it.
Old Jul 27, 2018 | 05:05 PM
BigDan's Avatar
thanks hanky
ill check because I dont think i have a check engine light on
Old Jul 27, 2018 | 07:20 PM
You would then watch the deflection of the needle on an Analog voltmeter and count the times the needle rises and falls.
danford1
Sep 12, 2014 10:58 AM
wingmylife
Mar 3, 2013 08:17 AM
MichaelC
Dec 11, 2012 02:16 PM
fl_hayseed
Apr 23, 2012 07:06 PM
grandmarq
Feb 14, 2012 01:27 PM
