Finally a van
Old Jun 18, 2023 | 07:31 PM
BinofSin's Avatar
Default Finally a van
First post here. I wanted a van when I was an impressionable youth back in the mid 70s. Finally bought a 2001 E150. Really liking it, but has a few issues. Had to come to a quick stop today from 5mph. Engine stalled, restarted but now idles rough and is down on power. Thinking it's something stupid. Code P0174 displays. Any input will be appreciated!
Old Jun 18, 2023 | 09:48 PM
ThisGuy's Avatar
Hey bud. Congrats! I just bought my first van a few days ago as well. That code sates that the engine is running lean and the air/fuel mixture is more air than normal. Not sure what to check for regarding this specific engine, but in general you want to follow all the vacuum lines to inspect for damage and see if any are disconnected. Also, follow the intake to the throttle body and intake manifold and see if anything is loose or cracked that is introducing air into the system. An easy way to find a leak would be to take a can of brake cleaner or carb cleaner and spray it around the intake or vacuum lines. If the engine reacts (as in hearing a change in idle speed) you can narrow down your search to that area. Use this at your own discretion, but its always helped me find leaks. Best of luck to ya man.
Old Jun 18, 2023 | 10:00 PM
BinofSin's Avatar
Thanks for the stone-age diagnostic tip. That makes sense that something was jerked loose. Definitely a great way to eliminate a vacuum leak. My old 1968 Cortina would unplug it's own coil wire if I took off too fast from a stop.
Old Jun 19, 2023 | 04:46 PM
BinofSin's Avatar
Armed with a can of carb spray, I found that the throttle body air intake had come partially off. Thanks for reminding me of the old trick.
Old Jun 19, 2023 | 07:14 PM
ThisGuy's Avatar
Glad it worked out for ya man!
Rodney V
Apr 7, 2020 08:35 PM
Weekend Wrench
Apr 1, 2014 08:41 PM
ajsanteiro
Dec 3, 2012 07:42 AM
Jackson2
Oct 9, 2009 11:30 AM
daddymichael
Mar 17, 2008 04:48 PM
