Ford F150 Full Size Van
Old May 15, 2008 | 08:21 PM
rtb20926's Avatar
Default Ford F150 Full Size Van
2003 - F150 - Full Size Van
Anyone know how to disable the seat belt alert. You know the chime that alerts you every 30 seconds it seems, that your seat belt isn't latched. I would love to disable it!
Thanks!
Old May 15, 2008 | 08:25 PM
rtb20926's Avatar
Default RE: Ford F150 Full Size Van
Sorry it's an E 150
Old May 15, 2008 | 09:32 PM
Guessing the 'F series' was a typo..
Here's the info for the deactivation/activation..
Belt Minder Deactivating/Activating
[/align]Preparation
[ol][*]Before deactivating/activating the belt minder, set the parking brake.[/ol]
[*]Place gearshift in P (Park) (automatic transmission) or the neutral position (manual transmission).[/ol]
[*]Place the ignition switch in the OFF position.[/ol]
[*]Close all the vehicle doors.[/ol]
[*]Unbuckle the driver safety belt[/ol]
[*]Place the parklamps/headlamps switch in the OFF position.[/ol]
[/align]Deactivating/Activating
[ol][*]Turn the ignition switch to the RUN position. (Do not start the engine.)[/ol]
[*]Wait until the safety belt warning lamp turns off (approximately one to two minutes).[/ol]
NOTE: Steps 3 through 5 must be completed within 60 seconds or the procedure must be repeated.Buckle then unbuckle the safety belt three times, ending with the safety belt unbuckled. This portion of the procedure can be done before or during belt minder warning activation.[/ol]
[*]Turn the parklamps/headlamps on then off.[/ol]
[*]Buckle then unbuckle the safety belt three times ending with the safety belt unbuckled. After this step the safety belt warning lamp will be illuminated for three seconds.[/ol]
[*]Within seven seconds of the safety belt warning lamp turning off, buckle then unbuckle the safety belt. This will enable the belt minder if disabled or disable the belt minder if enabled.[/ol]
[*]The following sequence of events confirm the belt minder is enabled:
[*]flashing of the safety belt warning belt lamp four times per second for three seconds[/ul]
[*]three seconds with the safety belt lamp off[/ul]
[*]flashing the safety belt lamp four times per second for three seconds again[/ul][/ol]
[*]The safety belt lamp flashing four times per second for three seconds provides confirmation of belt minder disabled.[/ol]
[*]After confirmation, the deactivation/activation procedure is complete.[/ol]
Trdfjboys
Mar 22, 2014 03:28 PM
berning.36
Feb 26, 2009 03:43 PM
rtb20926
May 15, 2008 08:25 PM
leereb99
Jan 25, 2007 08:04 PM
maddjkr
Jul 12, 2005 07:14 PM
