i need help, so confused
Hi,
I have a 89 f-350 Econoline motor home I think it has the 302 v8. I start the engine and it runs fine at idle but when I go to give it gas it dies?!?!? Camper ran and started all summer sat for to weeks to winterize and all a sudden this issue happend. Please help!!!! Thank you |
Depending on where you had the RV, first off, check the engine intake system for possible tenants having moved in and they could have blocked incoming air.
A good visual inspection may reveal a cracked vacuum hose , look for anything different from what you were accustomed to seeing when you looked under the hood in the past. Did anyone do anything in the engine compartment in the process of getting ready for winter? |
(Post 94231)
Also, what is your fuel pressure like (last fuel filter replacement)? A dirty fuel filter just may have just shown its hand.
Originally Posted by Use Common Sense
(Post 94258)
Being a 1989, your fuel filter will be located along the frame rail under the driver's side.
(Post 95993)
You have a "HIGH PRESSURE" fuel system. It's best to remove power from the fuel pump and run the engine until it dies. They you will have a white clip on either side of the filter that get pulled up. Then the line pulls off of the filter ends. Don't worry if a clip breaks, as there should be a set of new ones with the filter. Just make sure they are in the box when you purchase the filter.
(Post 96013)
| All times are GMT -5. The time now is 09:23 AM. |
