Mirror removal
Old Dec 15, 2007 | 07:08 PM
roblenis's Avatar
Default Mirror removal
I have a 2004 e-350 cutaway chassie with a moterhome on it. I want to remove the rear view mirror, and use the mount and jointed arm to mount my rearview screen for the rear viewing camera. I can find no set screw like I have seen on our other vehicals. Is there a special tool I need? Please help. Thanks roblenis
Old Dec 15, 2007 | 08:51 PM
Default RE: Mirror removal
Position therear view mirrorin the 'full down' position..
Then, grasp therear view mirror and carefully continue to pull downward on the mirror until you see it pull away from the mounting bracket.. At that point, hold downward tension and slide/rock the mirror on up/off the bracket..
The rear view is held on with spring tension..
To install, slide the rear view mirror back down and over the bracket.. With moderate force, it will slide completly on..
Old Dec 16, 2007 | 08:58 PM
roblenis's Avatar
Thanks for the information on the mirror, I will try it in the morning.
Dr76
Jul 30, 2010 10:25 PM
FordLover1963
Nov 24, 2008 08:09 PM
saintdog1
Aug 27, 2006 12:44 PM
DRP2000
Feb 7, 2006 09:29 AM
mooncruiser
Sep 6, 2005 02:19 AM
