Need Help rewiring in a 84-85 Econline Van
Old Dec 5, 2005 | 11:02 PM
robyn7728's Avatar
Default Need Help rewiring in a 84-85 Econline Van
does any one have the diagram for rewiring my van. im having trouble with the brake and turn signals on my van and i use it as a ice cream truck and ive replaced bulbs fuses and it seems nothing is going to work. id appreciate any help i could get Thanks Robyn
Old Dec 6, 2005 | 10:06 AM
Ramrod48's Avatar
Default RE: Need Help rewiring in a 84-85 Econline Van
Sorry dont have a wiring diag. for that vechile , One question however , You are aware that the brakes an turn signals run through the turn signal switch on the steering coloum.
I have seen a faulty switch drive folks batty trying to figure out why they have no rear lites .
Also try this web addy , only takes a few minutes to register, if they cover your vechile you should be able to pull up a wiring diag. off it , good luck
WWW.autozone.com
gbowl
May 21, 2014 04:27 AM
gbowl
May 20, 2014 11:47 PM
p40whk
Aug 22, 2012 02:45 PM
Vancrazy
Dec 26, 2007 06:23 PM
falbazar
Mar 2, 2005 07:13 AM
