power window issues
Old Aug 21, 2013 | 09:22 AM
me jetmoto's Avatar
Default power window issues
does anybody know where the relay for the power windows is located?
edit: 1988 e150
Old Aug 25, 2013 | 01:24 PM
go-part's Avatar
Former Sponsor
Old Aug 25, 2013 | 04:07 PM
Rusty Baker's Avatar
How about on an '85? I have a picture of the fuse block, just need the exact location of the window motor relay.
Old Aug 25, 2013 | 06:30 PM
If you can't locate a good schematic with color codes,you may have to do this the hard way and that is determine which color wire sends power to the power window switch then look for a relay that has that particular wire coming off it. I don't recall if they used a relay block. They possibly used an independent relay and colors are easier to chase that way.
Old Aug 26, 2013 | 10:02 AM
Just looking for an easy, quick way to get the window lowered. The heat index is over 100 every day. Too hot to spend more than a couple minutes at a time working on it. Also, too hot to drive it with the window closed.
Old Aug 26, 2013 | 01:40 PM
I've been told many times to go to there. I hope you're not where I think you are !!
Old Aug 26, 2013 | 02:55 PM
me jetmoto's Avatar
You can always take the panel off, remove the motor and let gravity do the rest. There is just enough room to push it back up and wedge a screwdriver in there to keep it up. Don't ask me how I know this.
Old Aug 26, 2013 | 04:43 PM
This is a stupid custom van. It takes a long time to pull the panels.
Old Aug 28, 2013 | 11:42 PM
me jetmoto's Avatar
well, then your other option is a rock or hammer for instant ventilation
Old Aug 29, 2013 | 08:10 AM
I have seriously considered that. Just hoping it will cool down a little. 96 today with a H.I. of 105.
