radiator replacement
Old Oct 23, 2006 | 11:39 AM
buzzlightyear's Avatar
Default radiator replacement
hello my 1994 e150 ford van needs to have its radiator replaced, she has 186,000 miles. is it a project that i can handle myself or should i let a repair shop do it? i'd rather save the money and do it myself. any advice would be appreciated.
Old Oct 23, 2006 | 04:15 PM
Mulletman's Avatar
Default RE: radiator replacement
You can do this yourself. Remove the air cleaner housing, remove the grille, remove the shroud, remove the hoses and trans lines, find the radiator mounting bolts through the front of the grille area.
Old Oct 23, 2006 | 04:52 PM
thanks for the response, should i also replace the waterpump even though it doesnt leak? its the original
Old Oct 24, 2006 | 11:58 PM
Mulletman's Avatar
If it is not broke, don't fix it!
sephi
Dec 7, 2014 04:47 AM
factory310
Apr 28, 2007 06:23 PM
daleh1
Mar 6, 2006 08:46 AM
blksabbath
Feb 9, 2006 04:04 PM
pistonluck
Apr 26, 2005 03:43 PM
