should I change to 3 73s
Old Aug 30, 2022 | 04:36 PM
CTP2022's Avatar
Default should I change to 3 73s
I have an 01 e150 with the 4.2 6cyl. The van is my work van and I have at least bare minimum 1500 pounds in it all the time some times touching 2000+. my question is, would swapping to 3.73s from 3.55s acutally hurt fuel economy since its so lugged down with weight? I want to believe it wouldnt hurt it and may even help it. Im getting about 13mpg average right now.
Old Aug 31, 2022 | 01:53 AM
raski's Avatar
Changing the ratio to 3.73 will increase performance at the cost of fuel economy. 13mpg with a fully loaded E150 is going to be the best you can expect. Keeping the tires correctly inflated for the loads you are carrying will help a lot with your mileage.
Old Sep 16, 2022 | 02:42 PM
awack's Avatar
my 5.8l had 3.73 from Ford. Now has 4:10 . It used to get 18mpg on the Freeway with a tail wind empty. now it gets 10mpg if lucky. But it will crawl up a tree .
Mine is a 4x4.
Old Sep 17, 2022 | 11:06 AM
raski's Avatar
Mine is a 4x4.
That is to be expected. Higher RPM means more gas is consumed.
Lissa S
May 10, 2017 06:30 PM
petec
Aug 6, 2015 11:37 PM
madmax23
Jul 5, 2012 09:20 PM
tgolds
Apr 26, 2011 03:02 PM
l0st1
Apr 21, 2009 11:48 PM
