Trailer brake and 7 way plug on 2003 E350
Old Jan 2, 2017 | 12:48 AM
Nolan421's Avatar
Default Trailer brake and 7 way plug on 2003 E350
Hello,
Just picked up an 2003 E350 and need to tow with it. I am attempting to install the 7 way plug with trailer brakes. I have found a factory 4 plug under the rear bumper and followed it back to a connector with only 4 wires connected. where can I tap into the other wires?.
Under the steering wheel I have found the plug for the brake controller.
Can some one guide me on how to install the 7 plug?
Old Jan 2, 2017 | 10:40 AM
Thumbs up
Welcome to the site.
The factory brake controller 6 wire connector s/b to the left of the column, coming out of the harness trunk.
For ID,, Connector color is brown,, Wire colors should be,
DB, BK, LG, LG?, LB/BK, BN
Is that the connector your viewing?
Look at the left/rear frame area, s/b 2 connectors there, both black, one will have your 4 connector harness plugged in.
Old Jan 2, 2017 | 11:00 AM
Nolan421's Avatar
Thanks for the reply. Please see attached images.
Picture of 4 way plug, picture of connection after following 4 way plug up the frame, and picture of brake controller connector under dash/steering wheel.
I would like trailer battery charge.
Attached Thumbnails Trailer brake and 7 way plug on 2003 E350-img_9027.jpg   Trailer brake and 7 way plug on 2003 E350-img_9028.jpg   Trailer brake and 7 way plug on 2003 E350-img_9029.jpg
Old Jan 2, 2017 | 11:15 AM
Nolan421's Avatar
All necessary fuses are present in fuse box under the hood as well.
Old Jan 2, 2017 | 09:48 PM
Correct on the brake controller connector.
I'll send you a couple of connector/ location views, there should be 2 trailer connectors towards the back. They'll give an idea of wire color, connector configuration..
Old Feb 5, 2017 | 01:43 PM
Fritz75's Avatar
Any chance you could post those views here. I'm looking for the same info. Have factory 4 wire tow package. Want to convert to 7 wire. Know where 4 wire harness plugs in the main harness drivers side rear, but don't know where the power/E-brake signal connector is.
Thanks!
rdandcc
Nov 15, 2011 09:04 AM
becksbikes415
Jul 27, 2011 07:24 PM
boonestar
Mar 9, 2011 07:14 PM
E350turbodiesel
May 7, 2009 02:39 PM
93f250xlt4x4
Jul 3, 2008 10:02 AM
