2003 F250 Trailer brake wiring
Old Apr 3, 2007 | 09:59 PM
rdandcc's Avatar
Default 2003 F250 Trailer brake wiring
The truck came with the factory tow package. I found the trailer brake adapter in the glovebox but I can't find where it plugs in under the dash. I did find 4 wires without a plug that the colors match that run from under the dash thru the firewall. They aren't hooked up to anything out there.
Thanks,
Randy
Old Apr 3, 2007 | 11:29 PM
Default RE: 2003 F250 Trailer brake wiring
The wires that run through the firewall are 'customer access' wires (firewall pass through) and aren't for the brake controller.. Remove the drivers/lower dash access panel, look over to the far upper rightand you'll see the dash support braket with attachedgrounds.. Around the 'back side' of the bracket you shouldsee the controller connector.. May be snapped into a cover/plug..
Old Apr 4, 2007 | 12:43 AM
rdandcc's Avatar
Thanks for the info and quick reply!
Old Nov 15, 2011 | 09:04 AM
jessy's Avatar
A good post that really helped me also.
Thanks a lot for the information.
93f250xlt4x4
Jul 3, 2008 10:02 AM
akilgore
Sep 26, 2007 02:18 PM
pkeck
Jan 16, 2007 08:37 PM
Spade
Jan 1, 2007 03:45 AM
jakec8
Dec 3, 2005 02:26 PM
