transmission supporting CROSSMEMBER removal 1975 e250
**solved** - cutoff wheel, new bolt... ¯\_(ツ)_/¯
I am in the process of removing the transmission to replace some seals, and I've become stuck at removing the Crossmember that supports the Transmission.
I have removed the nuts on the 6 bolts coming thru the lower portion of the crossmember. is it necessary to remove the angled support arms as well? I'm having trouble loosening the fasteners hidden up in the main frame rails. Access to these bolts are quite limited.
