Van is now 31 yrs old. do I still need to have...
Old May 18, 2020 | 08:14 PM
Welderguy's Avatar
Default Van is now 31 yrs old. do I still need to have...
being that my van is now 31 years old, and I no longer am required by my state, to have annual inspections, should the EGR be bad, DO I really need to have the EGR attached? or could I remove it and engine be just fine? And I am referring to physically removing it from the throttle body, and placing a steel plate with gasket, over the opening on the throttle body.
and the engine still run good?
Old May 20, 2020 | 06:44 AM
raski's Avatar
If you have your sights set on removing it, just disconnect and plug the vacuum line to it. Myself, I wouldn't. It's function is to lower NOX emissions by cooling the combustion chambers. Your engine would have a greater tendency to ping without it. There's nothing to gain by removing it and they rarely go bad. I only seen one in 30 years and it had a hole burned through the pintle..
Welderguy
May 19, 2020 06:18 AM
makuloco2000
Jan 17, 2014 07:06 AM
bgdv485
Jan 2, 2009 09:25 PM
spinbad
Mar 20, 2008 09:10 AM
tnfritch
Jul 9, 2007 07:28 AM
