Voltage Regulator 1988 E-150
Old Dec 15, 2009 | 07:46 PM
mhepner's Avatar
Default Voltage Regulator 1988 E-150
Where is the voltage regulator located in a 1988 E-150 van? Is it internal or external?
Thanks
Old Dec 17, 2009 | 12:40 AM
toxSoongero's Avatar
Default Voltage Regulator 1988 E 150
I think I have a voltage regulator thats blown. One of them lets battery power through one way, but doesnt let ac power through the other way. I just want to identify the IC so I can get the datasheet and test it some more.Here are the markings4890AK?L57A Its 8 pins, 4 on each side. I cant make out the manufacture logo.
Old Dec 19, 2009 | 11:23 PM
The voltage regulator should be between the power supply and everything else. If you were to wire the regulator after the controller it would try to keep the voltage to the car constant The regulator itself only uses a tiny amount of power, it is the load that uses power. Actually a number of our tracks use diodes and we have never had one burn out. I tend to use 6 amp diodes, it does not hurt to have a circuit breaker for each lane. The regulators are supposed to have built in current limiting, but I would not bet my life on that.
redfalcon
Nov 15, 2012 02:12 PM
joachim1340
Jul 11, 2012 09:29 AM
devinjohnson125
Aug 4, 2010 03:03 PM
rlevy64614
Jul 23, 2007 08:32 PM
rhondaliz
Nov 25, 2005 09:17 PM
