What tires for my E-150 Chateau?
Old Nov 11, 2013 | 03:05 PM
OraDBAforPsoft's Avatar
Default What tires for my E-150 Chateau?
I have a 2005 E-150 Club Wagon Chateau 5.4L V8 Auto.
The current tires are no longer being made by Michelin:
They are P235/70 R16 LTX M/S
Other tires are available, but apparently the load factor is wrong.
I believe the Chateau requires a load factor of 107.
When I select other tires the same size/load factor from eBay for example, it shows as not compatible with my van.
Costco also has no tires that will fit it, suggesting I go to Discount Tire.
What are you using? Is the an official Ford recommendation?
Old Nov 12, 2013 | 08:41 PM
rhettjstone's Avatar
If you're looking for winter tires, I've had really good luck with the Bridgestone Blizzak...
Old Nov 13, 2013 | 08:28 AM
I live in Texas so don't think I need Winter tires - also, I was looking for LT235/70R16 with a load factor of 107 or higher.
Old Nov 13, 2013 | 10:29 AM
To get the load carry rating you want, l think you'd need to plus or alternate size tires. LT 245/75/16's rate 109..
Old Nov 13, 2013 | 11:36 AM
Will they still fit on the same rims ?
Old Nov 13, 2013 | 08:13 PM
Yes..
We run Nitto LT's on my wifes 150 4x4. Stocks were P's..
Old Nov 29, 2013 | 11:55 AM
Boxer19's Avatar
Are you sure they don't make them? I bought tires from Sam's Club in Mar 03 made by Michelin #P235/75R15X 108TXMS2. I know they are 15"....maybe they stopped making the 16".
Old Nov 30, 2013 | 11:28 AM
Default yes
100% sure. Both The michelin and costco sites, and in person confirm that.
P235/70 R16 are not available with the correct load rating.
Old Nov 30, 2013 | 11:29 AM
Resolution. I found some Hankook Tires online that met the size and load requirements.
Perhaps in the future Michelin will make them again or else I will go with a different size - thanks for the comments.
mboardman
Aug 10, 2014 01:15 PM
Sorry_Bastard
Jun 8, 2013 06:52 PM
sodatex
Sep 3, 2011 01:02 PM
sunshine
May 2, 2009 11:11 AM
AUPoleVault
Aug 19, 2004 04:29 PM
