Brakes Squeal In Reverse
When we had the brakes done on our 2010 Edge, they began squealing when backing up in. The dealer who services the vehicle maintains that is normal. How can we have the brakes corrected to stop the squealing?
If your brakes squeal in both forward and reverse, these may be the source of the problem. Your wear tabs, located at the end of the brake pads, can rub against the rotor to create this noise, and this can be an indication that your brakes need replacing.
maxpower
Jun 24, 2013 08:58 PM
