compass stuck on west
Old Jun 2, 2021 | 01:12 PM
Crashdawg's Avatar
Default compass stuck on west
Hello all. a newbie here. new to forum and the ford edge. im hoping someone can help me with this.
i recently purchased a 2012 Ford Edge and the compass is stuck on west. the only information i can find says to hold the re set button untill CAL shows up and then drive in circles. they also said the re set is on the back of the mirror. well i see no hole for the paper clip to re set. any idea where the re set button can be? Thanks for the help..Crashdawg
Old Jun 2, 2021 | 08:42 PM
scott.butler4's Avatar
Compass Calibration
NOTE: This procedure only applies to vehicles without SYNC®.
  1. NOTE: For optimum calibration, drive to an open, level location away from large metallic objects or structures. Switch off all non-essential electrical accessories (rear window defrost, heater, A/C, map lamps, wipers, etc.) and make sure all doors are closed.
    Start the vehicle.
  1. Access the message center main menu screen. Using the up and down arrow buttons scroll and select the Convenience tab. Press the OK button.
  1. Using the up and down arrow buttons scroll and select the Compass tab. Press the OK button.
  1. Press and hold the OK button to calibrate.
  1. NOTE: This takes up to 3 circles to complete calibration.
    Slowly drive the vehicle in a circle at no more than 5 km/h (3 mph) until CIRCLE SLOWLY TO CALIBRATE changes to CALIBRATION COMPLETE in the message center.
  1. The compass is now calibrated.
trev0006
Nov 20, 2013 01:08 PM
BlueOvalDude
Aug 12, 2011 11:52 AM
lynnie10
Jun 27, 2010 02:00 PM
crapjacks20
Apr 23, 2007 02:31 PM
zndad
Jan 30, 2006 03:52 PM
