New brake booster problem
Old Nov 8, 2024 | 01:26 PM
Burronator's Avatar
Default New brake booster problem
Hi all,
I have a 2013 Edge ecoboost FWD. After getting a hard pedal (and driving it that way for a couple weeks) I replaced the brake booster. Other than needing my little girl to crawl under the dash, it wasnt all that bad.
Having a problem now though- when driving, when i push the pedal i get the typical booster help for about the first half of the pedal travel. Then it hardens up like a bad booster if i need to come to a complete stop. Ive bled the front brakes just in case, but i never removed any lines while i replaced it anyway.
Any thoughts?
Thank you!
Old Nov 8, 2024 | 04:20 PM
Your brake booster is vacuum assist. Suggest you start with checking for possible vacuum leaks.
After that check the check valve that plugs into the booster
Hard pedal usually is the result of no vacuum assist.
Old Nov 8, 2024 | 05:52 PM
Burronator's Avatar
Thank you! I will check this weekend. Any good methods without a vacuum tester?
Disregard- I'll pick one up tomorrow, as well as a check valve. Inexpensive stuff.
Old Nov 9, 2024 | 06:39 AM
You should not need a vacuum tester.
Simon 66
Sep 29, 2023 03:23 AM
Steve Knotts
Sep 16, 2019 03:41 PM
Moondoggie
Nov 27, 2015 04:27 PM
BOBMAC
Nov 19, 2014 01:45 PM
jonas74
Aug 7, 2005 11:25 PM
