Spare Tire Substitute
Old Apr 27, 2021 | 09:12 AM
martinjose's Avatar
Default Spare Tire Substitute
Hello,
Had a tire go down after hitting a curb and the tire was cut. Not repairable. Good thing I have road hazard coverage. However, major issue was this occurred on a Saturday nigh in San Marcos, TX and could not find a place that sold a tire i needed. 265/40/r21. Had the donut on and needed to get back home which was over 250 miles drive. Not good on a donut. Luckily I was able to find a used 265/45r21 and made the trip home with no issues.
My question, is can I use a different rim size for a spare? Say a 265/45r20. Based on tiresize tire is an almost equal match. +0.3% diameter.
What does the forum member think?
2020 Edge ST does not have the brake upgrade
Old Apr 27, 2021 | 07:05 PM
scott.butler4's Avatar
Honestly I would have no issue going 200 miles on a donut spare assuming the vehicle is not loaded down.
I believe you are asking if you can get a full sized spare that the is a slightly different size then the four regular wheels.
Its not great to ride on different sized tires if they share a axle, if you are front wheel drive only and put the slightly smaller spare on the rear I do not see that being a issue.
Your existing stock spare tire is probably not a exact match in diameter to the other four tires.
vanbusguy
Dec 14, 2015 03:33 AM
brianf150xlt
Feb 5, 2013 06:05 AM
inmor812
Jan 18, 2009 04:17 PM
GJ450
Dec 29, 2008 06:34 PM
Jonathanes91
Feb 3, 2008 08:23 AM
