Transmission Hell
Old Aug 23, 2018 | 05:41 PM
Gemma's Avatar
Default Transmission Hell
07 Edge just replaced the OSS and TSS sensors because of the bucking and stalling. Now it barely wants to pull off into 1st gear! Reverses fine and once it finally gets into the 2nd and 3rd gears it's fine until I stop then it stalls out. Also not reading fluid amount on the stick looks like there's nothing in there, no leaks. Help! I'm so over this truck!!!
Old Aug 24, 2018 | 10:26 AM
Gemma's Avatar
Default Transmission Hell still
Ok! As I previously posted I just had my OSS and TSS sensors replaced in hopes it would stop the bucking and RPM overage. Yesterday it would not read the trans fluid on the stick SO after putting 13 quarts in it's finally reading ( I feel it's to much) but it's not leaking, it's mixing in anywhere else. NOW the truck is stalling in 1st gear but after you get through that it's shifts and drives perfectly until I stop then it stalls at first gear again.
Old Aug 24, 2018 | 07:09 PM
Have you checked the radiator or coolant overflow bottle for any oily or soupy contamination?
bradleyheathhays
Sep 24, 2019 05:00 PM
Stephandchris Perez
Feb 16, 2017 11:12 AM
runningranger
Oct 14, 2013 06:00 PM
Ed Goerke
Mar 20, 2010 02:06 PM
NJWINDSTAR
Oct 28, 2007 10:06 PM
