05 escape 3.0 engine swap now won't idle
I swapped a motor from an 05 tarus when i did it turned over but sounded like it was out of time removed timing cover and changed the trigger wheel to the other notch now it will start and run but will not idle i have checked no vacuum leaks new intake gaskets plugs and I'm getting p0106 and p2195 but don't want 2 start buying sensors if I dont need 2 wasnt having problems with the with the sensors b4 the motor swap any advice would be appreciated thanks
