05 escape 3.0 engine swap now won't idle
Old Oct 18, 2017 | 12:36 PM
Mark Calfas's Avatar
Default 05 escape 3.0 engine swap now won't idle
I swapped a motor from an 05 tarus when i did it turned over but sounded like it was out of time removed timing cover and changed the trigger wheel to the other notch now it will start and run but will not idle i have checked no vacuum leaks new intake gaskets plugs and I'm getting p0106 and p2195 but don't want 2 start buying sensors if I dont need 2 wasnt having problems with the with the sensors b4 the motor swap any advice would be appreciated thanks
460frank
May 14, 2016 01:40 PM
markf1971
Sep 14, 2014 11:20 AM
93f250xlt4x4
Jul 3, 2008 10:02 AM
e_Yiorgos
Dec 31, 2007 12:45 AM
