09 liftgate lock
I have an 09 escape that the liftgate sometimes will not unlock so you can open it.The keyfob unlocks the doors but not the liftgate.I have had it back to the dealer but it always works for them.It also wont open with door locks.The only way it opens is to put the key in and start the car then it works.Any ideas?
Mine will not open, even with the key in. The dealers want 95.00 just to look at it. Now my rear turn signal wnet out and i can't get access to change the bulb. No one will tell me anything. Did you have any luck?
It appears that the trim panel can be removed from the inside of the vehicle.
Hopefully that allows you to pry open the latch, or spray lubricant to the actuator, or apply voltage to the actuator (try a 9V battery). The liftgate consists of the following components:
REMOVAL AND INSTALLATION Liftgate Latch Removal and Installation
http://c.fixya.net/fixya20/uploads/Images/90F640F.gif Good luck |
Tailgate Won't Open - Actuator not Latch
I have a 2009 Ford Escape and the tailgate, which was temporarily not opening is now permanently closed. I ordered the Tailgate Actuator Assembly and need to know how to open the tailgate when the actuator no longer works. The previous information in this thread is for a latch for circa 2001 Escapes. From 2009 to 2012 they used actuators, not latches. Does any know where I can get the information on how to open the tailgate? Any help would be appreciated.
Also a bit of information I haven't seen in other forums - When the tailgate actuator or the rear glass actuator is working intermittantly you can turn the ignition key to ACC and then off again. This will reset the solenoids and you should be able to open the tailgate or glass. However this is sign that it needs to be fixed. This is only a temporary condition. |
Hi I am having a similar issue. My trunk release has a mind of it's own, it works for awhile then it does not work for a while. I am reluctant to spend the almost $200 dollars for the part, put it in myself only to find out is is the harness or something. Have you fixed your issue? Did stop working completely or on and off as mind doe? Thank you.
I did end up replacing the mechanism and it did fix the issue. Its MUCH easier to replace it before it dies completely. I looked around and got it for $89.00 on ebay. It was new and the correct part.
| All times are GMT -5. The time now is 01:39 AM. |
