2002 V6 Escape Instrument Cluster resets itself while driving
Old 03-08-2011, 03:44 PM
sharkyg60's Avatar
Default 2002 V6 Escape Instrument Cluster resets itself while driving
I have a 2002 V6 Escape XLT with all the options. The problem is that when driving at random times, the Tach and the Speedometer pinned all the way to the right then go to zero and back to where they should be. It seems just before that happens, the car hesitates just a bit, if any. Any help would be great!!!
Todd
Old 03-08-2011, 06:16 PM
Douglas_48's Avatar
Todd
That sounds like it could be an electrical issue or something in the wiring... Hillsboro Oregon Mercedes Benz Auto Repair Mechanic Service Center
Old 04-09-2011, 06:20 PM
Nilsa's Avatar
Hello ! I have the same problem; did u find out what was wrong? Tku
Nilsa
Old 04-09-2011, 07:50 PM
Might want to check out VSS , vehicle speed sensor.
Old 04-10-2011, 06:03 PM
Nilsa's Avatar
Default Not only the speedometer, but also the gas indicator and the tachometer
Thanks for your reply, but the problem is with also the tachometer, and gas indicator.
All of the clocks are down; it started with the needles moving
pls advise
tku
Nilsa
Old 04-22-2011, 04:34 PM
inch's Avatar
Default Have same problem
have same trouble anyone had any luck finding cause?Thinking of replaceing cpu
Old 04-22-2011, 06:22 PM
The reason I suggested checking the VSS (vehicle speed sensor) is because some manufacturers tied the VSS into the same circuit as some of the rest of the gauges. Unless you were aware of this possibility you would never expect them to share the same circuitry.
Old 01-14-2014, 08:17 AM
Maddog999's Avatar
I have a 2003 that does the same thing. I noticed the dash lights also blink when this happens too. The gauges peg and then go to normal. Did anyone try the VSS ? Or resolve? I was thinking the panel may be bad and replace it. Its just dash screws and a few connections.
makuloco2000
04-06-2014 09:55 PM
mgford2002
10-24-2012 10:02 AM
shr14
02-18-2012 09:41 AM
gpressick
07-14-2005 06:05 PM
jtt3769
06-04-2005 12:12 AM
Quick Reply: 2002 V6 Escape Instrument Cluster resets itself while driving
