2008 Escape 2.3L steering goes out every so often.
I have a 2008 escape as described above in the title that sometimes what it will do is when you’re driving down the road the steering gets really stiff and goes into manual mode and the engine light starts flashing. Unfortunately I have not been able to pull the code because it only happens for a few minutes and then it clears. I know there was a recall for this vehicle, and it was taken in, in 2017for the recall, but it seems like the issue is happening again. We did not own the vehicle when it was first supposedly recalled. Also, the dashboard is showing that the vehicle has over 991,000 miles which we know it does not. I’ve tried resetting the cluster but it keeps coming back with over 991163.5 miles, which I know it doesn’t have.
If you want to get that possible code you might leave your reader on all the time and you just might be able to catch it.
As far as resetting the mileage, it requires special equip to do that and sometimes the cluster has to be sent out to have that repaired. If everybody could reset their mileage the readings would be worthless.. |
Electrical issue
(Post 135467)
