2008 Escape Dome Light Issues
Old May 25, 2023 | 07:44 AM
mistere1974's Avatar
Default 2008 Escape Dome Light Issues
Hi,
I bought a 2008 Ford Escape, and I am looking for input please. I searched this site, and did not see the same issue.
I have to keep the dome light in the off position, otherwise it will always be on at all times - and even flashes sometimes.
I tried replacing all the bulbs to see if that fixes it - and I wanted bright white LEDs anyway.
Any ideas where to go from there?
If it was a fuse, it would either work, or not work, right?
Thanks for your input.
Old May 25, 2023 | 10:15 AM
Sometimes a door lock will provide a false signal to a control module which might perceive it as a door handle beginning to open a door..
Old May 25, 2023 | 10:19 AM
Thanks. I plan on lubing all the latches when I get home from work to see if that does anything.
Old May 25, 2023 | 10:22 AM
Let us know how you make out ,,thanks.
Old May 26, 2023 | 06:56 AM
*update*
I messed around with the dimmer again, and used a silicone spray on the latches and hinges - still nothing.
I am going to check out the fuses (which I do not think should be the issue), then check the connections on the dome light itself.
Old Aug 3, 2023 | 11:41 AM
**UPDATE**
The dome light did not work because the circuit needed to be reprogrammed.
It started because me tpms light was on, and replacing them did not fix it.
I went to another place and he hooked it up and said it needs programming, and that the dome light is affected by it.
$150 later, the tpms light is off, and dome light working.
Old Aug 3, 2023 | 01:25 PM
Thank you for the update.
pvplockness@gmail.com
May 20, 2017 06:21 PM
Herb Billett
Oct 14, 2011 02:35 PM
Billydsr
Mar 30, 2011 01:46 PM
bmcneely0
Dec 23, 2008 11:35 AM
torres
Jan 30, 2007 11:30 PM
