2008 Escape XLT high idle
After doing an oil change and replacing the air filter yesterday, my Escape is idling at a much higher rpm. At start, it shoots to between 2000 and 2500 rpm, then surges between 1500 and 1800 rpm. It does not drop down lower when driving, as it's high enough that I gain speed when my foot is off the gas pedal. I was not having these issues before the oil change/air filter replacement. It's weird because it doesn't seem like I unplugged cables or hosing, and nothing is loose around the air intake. Where should I begin to look to fix this? Thanks.
There could be a few reasons for an unwanted hi idle, but if this started only after you changed the oil and air filter, it might be a good idea to retrace your steps.
It is unlikely the oil change had anything to do with the new problem, but we can look into that a little later Where the problem could be is possibly what you moved/did replacing the air filter. I know you looked for vacuum leaks with hoses and that is a good place to start Suggest you go over everything you moved and look over, under, and around for vacuum hose or plug that may have come off or loose.Any check engine light? |
(Post 118358)
Can I ask if during your servicing did you at any time disconnect the battery?
(Post 118362)
