2008 Heating/Air Conditioning temps & fan not working
Hi All,
This past summer, my heating and air conditioning began acting up. I have a choice of 3 temps now; really hot, really cold and outside air. At about the same time, the first two settings on my fan stopped working. So now I can get the three temps on almost full blast and full blast.
Has anyone else had this problem &/or figured out the cause?
This is a 2008 XLT.
This is a 2008 XLT.
So after some scouting around, think I may know what the fan and air problems are. One is easy to fix, the other may require tools and know how I don't have.
The fan issue appears to be the "motor blower resistor". Digging around on youtube, found several how to videos and the part appears to be between $25-$30 and a simple do it yourself repair.
The heating/cooling issue may be the "blower door actuator" which while not difficult, requires taking apart the dash and possibly pulling the air bag. I'm not up to messing with either. But if you want to see
The fan issue appears to be the "motor blower resistor". Digging around on youtube, found several how to videos and the part appears to be between $25-$30 and a simple do it yourself repair. Replacing a Ford Escape Blower Resistor - YouTube
The heating/cooling issue may be the "blower door actuator" which while not difficult, requires taking apart the dash and possibly pulling the air bag. I'm not up to messing with either. But if you want to see 2008 Ford Escape Blend Door Actuator replacement - YouTube
Hi All,
This is a 2008 XLT.
This is a 2008 XLT.
SteveHolmes
Sep 24, 2012 09:55 AM
