2010 Escape Limited
Old Mar 8, 2021 | 02:27 PM
Mike A. Ransdell's Avatar
Default 2010 Escape Limited
Hello all,
I have recently purchased a 2010 Escape Limited V6 Flex Fuel with some a/c issues ( among others but lets start here )
I found that the blend door actuator on the drivers side was clicking, put a replacement in and the air definitely blows a little colder and the clicking has stopped but the passenger side is noticeably colder in temperature and the drivers side remains cool but not cold on max a/c.
Does anyone know where else to start? I'm normally fairly competent in performing my own diagnosis and researching but I cannot find out anything else to try.
Another note - I bought refrigerant however upon plugging it into the low pressure port, which was missing the cap I hope the valve isn't dirty/damaged, I found that the pressure was just between the needing to be filled and bottom of the filled area, but would jump up to the yellow alert zone on the pressure gauge that came with the Ez chill A/C refrigerant can-this seemed to happen when the compressor was kicking on/off.
I appreciate any notes or ideas regarding this, I hope I supplied enough information, let me know if you need anything else to help diagnose this with me. Thanks!
Solenya
Oct 6, 2023 10:23 PM
Jtmikan7
Dec 1, 2020 06:45 AM
MikePA
Dec 11, 2018 05:30 PM
cokekid
Nov 27, 2018 10:32 PM
Broncohound
Sep 17, 2017 09:18 PM
