2014 Edge Back Up Key Fob Slot
Old Dec 30, 2017 | 08:33 PM
craiglister1920's Avatar
Default 2014 Edge Back Up Key Fob Slot
I have a 2014 Ford Edge. I have been trying to set up my key less entry system located on the exterior door. Well you need the 5 digit FACTORY CODE. Well I watched several YouTube videos on "how to". I looked under the glove box and found a 5 digit number on a bar code. I attempted to setup my code and was unable to do so with that number.
I then saw a video on how you can use your key fobs to find out the factory code. It said "Place the first programmed key in the backup slot inside the center console". Then press start and wait 4 seconds. Then do same with the second fob. Well I could not find a slot to stick it. So I am hoping that some other Edge owner has figured this out so I can use my two key fobs to find my factory code and save me $100 having the dealer tell me what my code is. Please tell me where to stick my key fobs..... in my Edge to get it to work. Thanks!!
meokey
Nov 24, 2017 02:52 PM
MarshallGibson
Nov 25, 2015 09:54 AM
verna2197
May 6, 2015 06:07 PM
ericwilson54
Sep 16, 2008 05:54 AM
Mulletman
Jun 9, 2006 04:44 PM
