Escape compression.
Old Jan 3, 2018 | 05:39 PM
Chungaleta's Avatar
Default Escape compression.
Hi guys.
Ford Escape 2005 2.3 engine with 171k miles with even 120 psi compression across the board... Is too low?
Old Jan 3, 2018 | 08:52 PM
primem's Avatar
seems resonable.
is there a problem your are trying to fix
Old Jan 3, 2018 | 08:55 PM
Chungaleta's Avatar
Originally Posted by primem
seems resonable.
Nop, just checking the car to buy it. The weird thing is that the engine sounds like new and the car runs like new. Checked the compression just for the sake of checking and I was hoping for 175 psi or so.... I don't know if an engine with 120 psi can run that fine with no smoke at all. Another thing, I didn't open the throttle all the way when testing. Don't know if that affects the readings
Old Jan 4, 2018 | 08:28 AM
primem's Avatar
175 seems high...would see that on a high compression engine.
the engine should be warm
the throttle should be open
the battery should be fully charged
crank for about 6 hits, the first hit should be 50% of the final reading
inspect the spark plugs while they are out...should be white or tan colour with no deposits...deposits would indicate possible head issues
Old Jan 4, 2018 | 08:31 AM
Chungaleta's Avatar
Thanks a million, will do that and compare results.
Old Jan 6, 2018 | 05:19 PM
09XSCAPE's Avatar
and remove spark plugs if doing a compression test
the main point is consistency between cyl, which you seem to have
Subimike
Aug 19, 2011 05:41 AM
fishmishin
Nov 20, 2007 03:20 PM
QUAD
Oct 31, 2007 08:19 AM
antwaugn
Dec 12, 2006 11:56 PM
antwaugn
Nov 25, 2006 03:19 PM
