2016 Ford Escape 1.6L P0228 & P007D Code
Hi everyone,
I am new this forum and would like the communities help in diagnosing my problem. I have a 2016 Ford Escape Ecoboost Turbo 1.6L 2WD 4-cyclinder. I started my vehicle one morning about to go to work and the engine light came out. I am getting the following codes below: P0238 - Turbo/Super Charger Boost Sensor A Circuit High P007D - Charge Air Cooler Temperature Sensor Circuit High Bank 1 Symptoms: Vehicle idles fine but runs very sluggish (stuttering) when attempting to step on the gas. The following code was present but is no longer showing after I cleared the codes using the obd scanner. P0236 - Turbo/Super Charger Boost Sensor A Circuit Range/Performance Is anyone familiar with the P0238/P007D code? I have tried to clean the MAF/MAP, check for vacuum leaks, wire issues (difficult to find as I am continuing to search). Any input will be great. https://cimg3.ibsrv.net/gimg/www.for...1a3436b887.jpg https://cimg5.ibsrv.net/gimg/www.for...09134e3e2.jpeg Thanks, Ethan |
| All times are GMT -5. The time now is 12:15 AM. |
