2016 Ford Escape 1.6L P0228 & P007D Code
Old Jul 4, 2019 | 08:28 PM
e10tran's Avatar
Default 2016 Ford Escape 1.6L P0228 & P007D Code
Hi everyone,
I am new this forum and would like the communities help in diagnosing my problem. I have a 2016 Ford Escape Ecoboost Turbo 1.6L 2WD 4-cyclinder. I started my vehicle one morning about to go to work and the engine light came out. I am getting the following codes below:
P0238 - Turbo/Super Charger Boost Sensor A Circuit High
P007D - Charge Air Cooler Temperature Sensor Circuit High Bank 1
Symptoms:
Vehicle idles fine but runs very sluggish (stuttering) when attempting to step on the gas.
The following code was present but is no longer showing after I cleared the codes using the obd scanner.
P0236 - Turbo/Super Charger Boost Sensor A Circuit Range/Performance
Is anyone familiar with the P0238/P007D code? I have tried to clean the MAF/MAP, check for vacuum leaks, wire issues (difficult to find as I am continuing to search). Any input will be great.
Thanks,
Ethan
bdoepke
Aug 19, 2019 07:15 PM
5653rhino
Jun 12, 2019 02:06 PM
kenneyp
Jun 7, 2012 08:09 PM
kmsalcido
Jun 4, 2007 10:21 PM
huntingsmoke74
Sep 15, 2006 05:21 PM
