airbag light 4-7 always on...
Check the connector on the 'passenger side' safety belt pretensioner for corrosion and/orfit.. The code is for an open or low resistance on the belt tensioner on that side.. They had a connectivity issue...
worked great! thanks! first i tried testing the seat belt socket, but it was good... so all i did was just plug the socket back in, and everything went fine! thanks a bunch. thank you ford forums!!
nickinma
Oct 23, 2006 02:51 AM
