Brake problem
Hi everyone, I have a problem with my 2015 Escape, 2.0 eco boost AWD, I replaced purge valve started a car so far everything is ok till I start to drive. I find out I have no brake. It’s hard brake pedal, if somebody went across same problem?
From what you have told us so far,
It is possible you may have dislodged a vacuum hose that goes from the intake manifold to the brake booster. The computer might be able to compensate for the vacuum leak or the hoses for the purge valve were installed incorrectly. where vacuum is not getting to the booster.. It would be a good idea to recheck your work and make sure the lines were all connected and connected correctly..
