Coolant change
Old Apr 25, 2020 | 01:04 PM
Sanddoc's Avatar
Cool Coolant change
Hi all
OK, first time I'm changing the coolant in my friends 2006 Ford Escape (yes I'm on a Ford forum)
So I've been reading and some sites say there is a coolant drain plug on the block.. If anyone Knows
if this is true, could you please tell em the location.
Another question is the automatic door lock inertia switch location. That's a mouth full
sometimes when the Escape moves forward the doors lock and the warning light on the dash panel goes out
sometimes they do not lock and the warning light stays on. And sometimes when driving the peep will sound
being linked to the door locks...
So if anyone know the location of this switch could you please tell me.
BTW.. using the manual lock switch sometimes does not turn the light off, even if it does lock the doors.
Thanks
Old May 20, 2020 | 11:25 AM
scott.butler4's Avatar
Ford does not list a engine block coolant drain. Just use the radiator drain, if you really want you can pull take off a engine coolant hose and let that drain out too, in my opinion its not worth it, I just open my radiator drain and let it empty out when I change my coolant.
OK on to the automatic door lock inertia switch location, which warning light are you talking about/what message is displayed?
Old May 21, 2020 | 07:17 AM
Sanddoc's Avatar
Seems kinda stupid not to have a way of draining most of the water from a black, in the older days
we had removable freeze plugs, and few blocks had although not called drain plugs would release water from the block.
I think the Escape uses 10qts of coolant...
about the inertia locks. the door lock icon in the instrament panels.. Indicates if a door or rear window is open..
It is set by either by the switch on the door or by the forward movement of the car. Just need to find the location
of that switch...
Old May 21, 2020 | 07:26 AM
3.0 engine takes 10 liters of yellow coolant.
So are you saying the door ajar light is on?
pdrc
Aug 30, 2021 01:14 PM
Marie
Oct 6, 2008 07:39 PM
Old Style
Jan 7, 2008 09:00 AM
expeditiondrivergirl
Nov 6, 2006 08:30 PM
Huhhhhh
Oct 2, 2006 01:19 AM
